Duken forum upgrade 4.1.*
Page 1 of 3Volgende
Heren en dames, in dit informatie topic zal ik de laatste update bijhouden van de forum software.
Alle eventuele toekomstige versies tot 4.1.* vallen in dit topic.
Bij een upgrade kan het forum trager aanvoelen ivm de heropbouw van de cache.
Zojuist draaien wij 4.1.9 met toevoegingen:
New or Changed Features
  • When your link auto-embeds in a post such as with an image, YouTube video, Twitter link, etc. an option will now display to revert the embed back to a plain text link if you do not want the embed.
  • New setting to disable embedding.
  • Facebook/Twitter integration improvements
  • If you are an administrator and encounter a system error, additional debug output will now display. Regular members will see the normal error message.
  • Custom Fields for Support Requests in Commerce now show on the front-end.
  • If an advertisement is set up with a main image, but not smaller images for tablets/mobiles, the ad would not show at all on tablets/mobiles. This has changed so the main image will display on all devices unless smaller images are provided.
  • Topics scheduled to automatically lock or unlock will now reflect this in the topic listing and when viewing the topic.
  • Placing a link to a Facebook status will embed when possible.
  • When viewing a report, the container (for example, the forum) the content is from is displayed.
  • Three character searches are now allowed in the Admin CP Live Search.
  • The Account Settings page now uses vertical rather than horizontal tabs to prevent overflow.
  • If Gravatar is enabled, and a user has not defined an profile photo, then their email address will be used to fetch from Gravatar unless explicitly set not to.
  • Gfycat embeds now use their oEmbed endpoint rather than their JS API.
  • Using Amazon CloudFront as https provider will now be recognized as valid secure connection.
  • The member REST API endpoint will now return custom fields.
  • The Developer Center for Plugins now shows the filename in the list of hooks, and when editing a hook, a breadcrumb includes a link back to the list.
  • Inline notifications can now be dismissed
  • Efficiency improvements to the search index
  • You can now close a poll independently of the topic
We zijn geupgrade naar versie 4.1.10 -  Bij een upgrade kan het forum trager aanvoelen ivm de heropbouw van de cache.
  • Instant notifications are now dismissible.
  • The sidebar has been added back to the stream pages.
  • You can now sort by most downloaded in Downloads app.
  • The ModeratorCP and AdminCP IP Address Tools now allow you to track the IP addresses used to vote in polls.
  • A new setting has been added to disable the RSS feed for activity streams.
  • A new setting has been added to specify the minimum display name length.
  • Adds a new "can unban" moderator permission separate to the "can edit profiles" permission being used previously.
  • IP addresses now show in reports.
  • There is now a constant-level setting to disable the ACP IP address check in case of being locked out of the ACP.
  • Several improvements to Commerce to make some features clearer: the Shipping Rates configuration pages now indicate to the admin if a potential mistake has been made, the front-end indicates to admins if no support departments have been set up, and the renewal settings wording has been clarified.
We zijn geupgrade naar versie 4.1.11 -  Bij een upgrade kan het forum trager aanvoelen ivm de heropbouw van de cache.
Updates en veranderingen:
  • Integration with SparkPost replaces Mandrill for optional email service as Mandrill is stopping their current service toward the end of April.
  • Questions in Question and Answer forums can now be sorted by most votes.
  • The "All Activity" activity stream now has an RSS feed.
  • The filter bar at the top of the activity stream no longer sticks to the stop of the screen when scrolling.
  • If you receive a browser notification your notification menu will now reload to get the latest notification.
  • More consistent visual feedback when a post submit or edit is processing to reduce duplicates.
  • Sidebar widgets now how rounded corners to match rest of Suite.
  • Recaptcha style is now a per-theme setting.
  • You can now set which theme should be the default for the AdminCP separate to which should be the default for the front-end.
Opzich handig, de RSS feed met de laatste berichten via http://www.duken.nl/forums/discover/all.xml
Ik weet niet of er leden zijn met RSS readers, maar het is een leuke toevoeging ;)
Hallo Duken,
Eerst maar even melden dat ik echt een hele tijd niet op het forum ben geweest. Maar door de  goede herinneringen aan de vreselijk goede hulp die ik hier altijd heb gehad en of heb kunnen opzoeken (zeker dus in mijn begin tijd op het download gebied e.d.) heb ik jullie website altijd in ere en hoog gehouden in mijn favorieten.  En nog,  als ik ergens op stuit wat mij onbekend is op pc gebied is het eerste wat in mijn hoofd opduikt Duken.nl Gelukkig ben ik ooit door jullie forum heel wat wijzer geworden waardoor ik al heel wat pc/download dingetjes zelfstandig kan doen al jaren.
En dan ontvang ik ineens een heuse nieuwsbrief in mijn email box van Duken.nl ?!?!?!?!? En wat voor één ! Een hele informatieve ! Met toch weer heel wat vernieuwend nieuws voor mij erin. Dus m.a.w. wat een leuke, goede en interessante nieuwe ontwikkeling van jullie. Ik ben  er weer wat wakker door geschud.   Hier en daar zijn  mijn vastgeroeste programmaatjes van jaren oud (nog steeds goed te gebruiken  hoor daar niet van) dus toch wel eens aan vervanging toe kom ik achter omdat  ik  in de nieuwsbrief lees dat er heel wat snellere en nog weer simpelere progjes voor diverse "werkzaamheden" inmiddels zijn ontwikkeld. Dikke pluim, hoed af en diepe buiging dus voor jullie voor deze nieuwe service (de nieuwsbrief dus)   (en jullie waren al zo goed) van een 58 jarige vrouw die gelukkig altijd netjes haar "brieven" leest (anders had ik de nieuwsbrief niet ge-opend en gelezen en had ik in mijn verouderde kennis blijven hangen) die ze ontvangt in haar email box. Dus dank jullie wel.
Een hele goedemorgen @Oita, wat een mooi stukje tekst! Daar werd ik wel heel erg blij van op de donderdag ochtend! Ook heel leuk om te horen dat we nog altijd in de favorieten zijn blijven hangen en dat je zo de nieuwsbrief echt handig vond. :)
Geen dank, en bedankt dat je even je reactie wou achterlaten. Daar worden we gelukkig van :proost:
We zijn geupgrade naar versie 4.1.12 -  Bij een upgrade kan het forum trager aanvoelen ivm de heropbouw van de cache.
Nieuw
Activity Stream enhancements:
  • The filter dropdowns now have an "Apply" button for better usability (previously you had to click outside the dropdown).
  • The "Expanded/Collapsed" toggles are now clearer.
  • Hitting back from a clicked item in any activity stream now remembers your position and loaded results.
Other enhancements and improvements:
  • The way dates are formatted can now be customised by language strings. For example, if you want to change the date format to "DD-MM-YYYY" that is now possible. With this change, the new default is US-style ("March 4, 1992") rather than the previous European-style ("4 March 1992").
  • Advertisements no longer have padding which makes them easier to position in other areas such as headers.
  • When comparing revisions of articles in Pages databases, a new browser-based diff tool is used which is more user-friendly and moves the computation from the server to the user's browser for greater performance.
  • Better indication of files pending approval in Downloads.
  • The version number for themes now displays in the AdminCP list.
Technical features:
  • If you are using the utf8 rather than utf8mb4 character set (which will mean you can't post Emoji) there is a new tool in the AdminCP to upgrade to utf8mb4.
  • System logs have been rewritten to use the database for logging where possible with a more user-friendly interface in the AdminCP.
  • Downloading files from Amazon S3 has been changed to redirect the user to a temporary download URL rather than serve the file through your server for significantly improved performance and reliability, especially with large files.
  • If it is available on the server, ImageMagick will now be used rather than GD by default. ImageMagick also has a new setting to control JPG quality.
  • APC User Cache is now supported in addition to APC.
Mooi forum!
Upgrade naar 4.1.12.2
Broken @mention links.
Merging members could cause follow records to be lost.
Email digests.
Incoming emails to Commerce.
Announcements expiring at the wrong time.
Error when editing database records or sidebar widget.
Error trying to establish external connection to certain servers.
Error redirecting from http to https.
Upgrade naar IPS Community Suite 4.1.13 uitgevoerd.
In addition to bug fixes and performance improvements, this release also includes following enhancements
  • New per-group setting to highlight posts made by certain groups. 2 theme settings control the color and border, which are editable in the easy theme editor.
  • New setting to make providing a billing address optional for purchases in Commerce.
  • Personal conversation management improvements:
    • Can now filter personal conversations to just read/unread.
    • Can now move multiple personal conversations into a different folder at once.
    • Can search by recipient/sender name.
  • Notifications about Calendar events now include the event date.
  • New setting to control which images sizes should have a watermark applied in Gallery.
  • New setting to control which IP pool to use for SparkPost if you have purchased dedicated IP addresses.
  • Better handling of upgrades if files have been modified.
  • The sidebar widget for showing Downloads files can now show just free or paid files.
  • When searching templates or CSS files in the AdminCP template editor, it will search for templates or CSS files with a name matching the term provided, in addition to searching the content of them.
  • When viewing a log in the AdminCP, it will now show you on which page the log occurred and by which member.
  • When the search index is being rebuilt, a message is now shown on the search results page to indicate why results may not be complete.
  • The "details" modal for applications and plugins now has a tab which shows the hooks associated with that application or plugin.
  • The placeholders that display on date/time inputs (e.g. "HH:MM") can now be translated.
  • Rebuilding the search index, and rebuilding posts after a 3.x upgrade now processes newest posts first for a more user-friendly experience after upgrading.
  • When a file is deleted, a log is created and a new setting controls how to keep these logs for.
The following Pages features are also included:
  • HTML pages are now editable via Designer's mode.
  • Ability to rename, or delete a group of Database templates
  • Ability to ensure the Page's title remains in all database generated links (categories, records, forms, etc)
  • Reciprocal linking when using relational fields
  • Date and time fields, and Yes/No fields are now filterable.
  • Filterable custom fields now available when creating a record feed block
  • Ability to make some custom fields unique, so that only one record per database can have the same value.
  • Ability to delete a folder in the media manager
  • Ability to use $record->field_key_name_here programatically to get and set values, instead of relying on $record->field_11 which may change when you export and import databases.
Page 1 of 3Volgende
