of Registreren om berichten en onderwerpen te maken.
bestanden decrypten na cryptoware
hulp gevraagd
ik heb blijkbaar iets gedownload en nu zijn mijn bestanden decrypt
hoe kan ik dat oplossen
---=    GANDCRAB V5.0.4  =---
***********************UNDER NO CIRCUMSTANCES DO NOT DELETE THIS FILE, UNTIL ALL YOUR DATA IS RECOVERED***********************
   *****FAILING TO DO SO, WILL RESULT IN YOUR SYSTEM CORRUPTION, IF THERE ARE DECRYPTION ERRORS*****
Attention!
All your files, documents, photos, databases and other important files are encrypted and have the extension: .FWNUSMP
The only method of recovering files is to purchase an unique private key. Only we can give you this key and only we can recover your files.
The server with your key is in a closed network TOR. You can get there by the following ways:
| 0. Download Tor browser - https://www.torproject.org/
| 1. Install Tor browser
| 2. Open Tor Browser
| 3. Open link in TOR browser:   http://gandcrabmfe6mnef.onion/b066090ea4829343
| 4. Follow the instructions on this page
On our page you will see instructions on payment and get the opportunity to decrypt 1 file for free.
ATTENTION!
IN ORDER TO PREVENT DATA DAMAGE:
* DO NOT MODIFY ENCRYPTED FILES
* DO NOT CHANGE DATA BELOW
---BEGIN GANDCRAB KEY---
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
---END GANDCRAB KEY---
---BEGIN PC DATA---
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
---END PC DATA---
Ik kan hierin @Drifter volgen maar er is echter een maar, en een belangrijke. De eerste link gaat over het verwijderen van het progje. echter geeft @Drifter aan dat het een virus betreft, en nu komt de maar, dit is geen virus maar malware . In één ding heeft hu echter geluk en dat is dat u getroffen bent door versie V5.0.4, anders had u echter minder geluk als u de volgende tekst leest:
Een nieuwe versie van GandCrab ransomware is uitgekomen, kort nadat BitDefender hun decryptietool heeft vrijgegeven en de GandCrab-ontwikkelaars ongeveer 1 miljoen dollar hebben gekost. De nieuwe versie heet GANDCRAB 5.0.5 en er is momenteel geen decodering voor gemaakt. U kunt echter onze herstel- en verwijderingsvideo bekijken van de 5.0.5-versie, die meer instructies en alternatieve methoden bevat die u kunnen helpen om ten minste een deel van de bestanden te versleutelen die zijn versleuteld met v5.0.5.
Een mogelijkheid is even te kijken op de volgende link Politie Nederland hier is zeer nuttige informatie te vinden waarna u zeker naar de volgende link moet kijken no more ransom daar selecteert u Nederlands waarna u op de pagina van de Crypto Sheriff terechtkomt hier kan u eventuele aanwijzingen volgen. Echter indien u volledig naar beneden scrold op de pagina no more ransom ziet u staan ontsleuteld en klikt u op Gandcrab en komt u op een gedeelte waar u  BDGandCrabDecryptTool ( is ontworpen om bestanden te ontsleutelen die versleuteld zijn door GandCrab (V1, V4 and V5 versions) van Bitdefender kan dowloaden. Hoe u de tool moet gebruiken staat op How to use the tool . Het is ten zeerste aangeraden dit te doen in safe mode van het besturingssysteem (het decrypeten van de versleutelde files om daarna de versleutelde files en Gandcrab te verwijderen). Hoe doet u dat? Wel volg de instructie van de video:
U ziet dat dit voor versie 5.0.5 is maar ook werkzaam voor 5.04
